Driveshaft opinions needed: I have a chance to get an aluminum D/S from a 95 Crown Vic....
December 29 2008 at 7:35 AM
  (Login MT63AFX)
..........Police Interceptor. Will this shaft fit/work in a Galaxie? Has anyone done this in theirs? If so, what is needed to make this usable? Thanks, Rod. BTW, check Classifieds for 95 Crown Vic for sale.
FGCofA member #4908
MCGC member #75
(Login qikbbstang)
FWIW I know a Mechanic @ Ford Quality Care and recall him saying
December 29 2008, 8:16 AM
there was an excessive number of Vic/Marquis driveshafts that were always being replaced for Vibration. I don't know about the HP your pushing but it might be wise to check the OD of a Marauder shaft. I know my factory Lightning Alum shaft is mighty fat.
I know I've seen dozens of the Vic/Marquis's with Alum Shafts hit the car crusher
This message has been edited by qikbbstang on Dec 29, 2008 8:18 AM
Tom P
(Login tomposthuma)
CrownVicky driveshaft
December 29 2008, 10:15 AM
I run one in my Fairlane without any problems except a slight decrease in elapsed times and increase in speed. happy.gif
It may be too short for the Galaxie, mine is about 53 1/2" center to center of Ujoints but 92 to new Crown Vics had a couple different tranny combos.
(Login MT63AFX)
Tom, did you change the yoke or u-joints because of size being different? Thanks.....n/m
December 29 2008, 11:18 AM
FGCofA member #4908
MCGC member #75
Tom P
(Login tomposthuma)
stock
December 29 2008, 4:36 PM
I use the Ujoint the driveshaft came with in the rear, just take that 4 bolt flange off. I needed to adapt the front because of the 1350 series slip yoke. The factory U-joints seem to be the best, i'd rather have one with 80,000 miles on it than a new replacement.
(Login MT63AFX)
Thanks Tom...n/m
December 29 2008, 4:59 PM
FGCofA member #4908
MCGC member #75
Current Topic - Driveshaft opinions needed: I have a chance to get an aluminum D/S from a 95 Crown Vic....
