OT...... Removal of siezed drain plug from block.....
December 15 2008 at 6:05 PM
  (Login mushoss)
I have a siezed drain plug which I stripped the allen on. I drilled it out to 1/4" and used my extractor to put as much force as I think the extractor can handle short of breaking. My next step will be heat. Question; how much heat can I safely apply to the area around this plug. Keep in mind that the cylinder is probably 3/8" away from this plug, (the width of water jacket). I will heat it in increments to try and break this loose, but if I have to get it glowing red will it hurt anything?
Craig Mitchell
68 Mustang GT 428CJ
(Login 1960townvic)
Get it glowing
December 15 2008, 6:11 PM
The change to cherry red changes the structure of the rust to something that will release. I cannot recall the details of the chemistry, only that this change in state for the rust is what makes it possible to seperate rusted nuts from the rusted bolts.
(Login Bad427stang)
Bingo
December 15 2008, 6:26 PM
All kinds of magic tricks out there, but there is nothing better than a bunch of heat
- 70 Fastback Mustang, 489 cid FE, TKO-600 5 speed, 3.70 9 inch
- 71 F100 shortbed 4x4, 397 cid FE, headers, Street Dominator, 280H, 5 lug Dana 60, 4 speed
(Login MT63AFX)
Is the block assembled or bare? Is it in a car or on a stand? You'll.......
December 15 2008, 6:18 PM
.......need to get it hotter than a dull orange to do damage, if bare and the front is not supported on a stand, JMO Rod.
FGCofA member #4908
MCGC member #75
This message has been edited by MT63AFX on Dec 15, 2008 6:18 PM
(Login mushoss)
Block is bare sitting on floor.......nm
December 15 2008, 6:22 PM
nm
Craig Mitchell
68 Mustang GT 428CJ
(Login kodiak427)
Do you have an air hammer?
December 15 2008, 7:00 PM
Before you use heat you may first want to try air hammer impact w/ a very dull chisel bit, w/ low air pressure. Impact the plug directly, and all around - - the dynamic shock may break it free so you can unscrew it w/ your easy-out.
(Login kodiak427)
. . . and use plenty of penetrant like PB Blaster.
December 15 2008, 7:06 PM
(Login 10w30dna)
Don't get the block glowing
December 15 2008, 7:10 PM
You can crack cast iron by geting it too hot and not cooling s-l-o-w-l-y...... Don't get too crazy w/ heat on cast iron blocks.
Engines are like garages,never big enough! Check out my distributor restoration site! http://428cobrajetcars.homestead.com
(Login fordsel)
heat the plug
December 16 2008, 2:57 PM
heat the plug nice and red if possible the spray it with water until cool, it will come right out.
RonW
(Login reman)
Craig.............................
December 15 2008, 7:17 PM
I'm sure you have read here about the candle wax trick. It works, I have done it many times. Lay your block over on its side and apply some heat. Get it fairly hot, but not red, then melt some of the wax around the plug. It will flow in around the rusty threads. Then try it again with your extractor and I'll bet it comes out. May need to repeat or turn the heat up slightly...........Sure sorry our timing was off the other day. I am looking forward to seeing the block and your new stuff. Be sure and ask me about driving my sons "new" 03 Cobra this weekend,lol. RonW
(Login winr1)
I had 6 17 year old muffler clamps deeply pitted, they usually break off, I sprayed....
December 15 2008, 7:26 PM
them 3 times a day for 4 days with PB Blaster and they backed off with a 3/8 ratchet and socket.
I always take plenty of time with rusted stuff in engine components.
Richard.
MeanGene
(Login 2many427s)
Learned a long time ago
December 15 2008, 8:04 PM
from my gramps, he owned a truck/tractor/car dealership, a truck fleet, and a few farms, worked in his shop since I was 5. Don't heat around the plug, heat the plug straight on, right in the center- it'll expand in the threads, and crush the rust in the process. After that is a great time for PB or wax- should come right out
(Login qikbbstang)
I've not tried it yet but the super markets now sell dry ice
December 16 2008, 7:10 AM
by weight. I wonder what shoving dry ice at -110F on a stuck bolt will do. Id figure the thermally caused size reduction and trama might loosen things up...
Devils advocate: heating can deviate ambient temp by hundreds to thousands of degrees a far greater spread
Mike
(Login Sunliner)
Re: OT...... Removal of siezed drain plug from block.....
December 16 2008, 7:49 AM
Have you considered tacking on a nut that you can then put a wrench or socket on?
(Login RM428)
December 16 2008, 9:59 AM
Over the years, I`ve had varied sucsess removing the block drain plugs. If it will require a huge amount of effort to get them out, I just leave em in. If you pop the core plugs out, everything will be drained anyhow, & I`d be pretty mad if I buggered up a block with too much heat, or mangled the plug so much that it broke off or leaked and couldn`t get it out anyways.
74 F350 ramp truck 390 4speed
Bill Ballinger
(Login BillBallinger120)
I am with you on that. If the block is bare knock out the core plugs
December 16 2008, 12:37 PM
Have the water pump off and put it in spot where it is "envionmentally friendly", like your queer neighbors flower bed, and douche it with a water hose, Blow it out with air, and its clean enough.
If its together, knock out the core plugs, pull the water pump and rinse it until all of the rusty crap comes out, then shop vac along the bottom, blow it out with air. I won't even attempt to get one of those plugs out, because you can get a sprayer and a shop vac attachment, or air hose in there much better with six ways to get at it.
(Login qikbbstang)
ROFLMAO...............Bill your "envionmentally friendly" approach was priceless n/m
December 16 2008, 2:05 PM
x
(Login mushoss)
Thanks for the responses...........Espicialy Bills
December 16 2008, 7:21 PM
I will try the moderate heat and wax. Although I don't think I have any queer neighbors I would consider pouring the antfreeze out so the neighbors unleashed, unfenced constantly barking dogs that aggravate the He** out of my fenced dogs could get a taste of it. Not really. As sure as I did not replace these 2 plugs they would leak, Hell, they will probably leak anyway. Besides I am thinking of installing drain peacocks in the place of them. I am appreciative of the responses, I will let everyone know the final results.
Craig Mitchell
68 Mustang GT 428CJ
Current Topic - OT...... Removal of siezed drain plug from block.....
