I found that I had to replace the needle/seat assemblies about once a year...
December 14 2008, 8:43 AM
because the 7-8 lbs pressure would eventually blow past them and and make it pour out black smoke. So a number of years back I put a regulator on and set it at 5.5 lbs and I haven't had to replace any more seats. With high pressure you have to adjust the floats lower to get the right fuel level at the window and the extra fuel pressure from the floats sitting lower in the fuel forces the viton coated needle harder on to the seat in order to seal and wears it out. I found that as soon as I reduced the pressure the fuel level dropped well below the window, and I adjusted the floats higher accordingly.
Of course this is assuming you are talking about the hi perf 7-8 psi Carter pump. The standard one is 5 psi and it will be fine.
Hollis Franks
Black 63 1/2 XL R Code
Gray 65 289 Falcon Ranchero
