Need a source for a new Receiver-Drier for my '66 Galaxie
December 13 2008 at 4:56 PM
Bob Sprowl  (Login bsprowl)
Anybody got a new one or know where to get one?
Could I plumb in any Reciever-Drier?
Bob
1966 7 Litre Convertible
1959 F-100 (under construction)
2005 GT40 (in my Dreams)
(Select Login ford428cj)
Have you tried Dearborn Classics???
December 13 2008, 5:33 PM
Have you tried Dearborn Classics??? I dont know for sure....
http://www.dearbornclassics.com/
"The Poor Mans 427"
"The F.E. Wiki Home"
http://fordfe.wetpaint.com/
Wes Adams FORD428CJ
03 F-250 Crew Cab 4x4 6.0 and 35's
64 Falcon X-Ram 428
2000 Yamaha V-MAX VMOA#4277
2000 Yamaha 700 Mountain Max
2001 Polaris 600 Edge X
2001 Polaris 500 SP
(Login bsprowl)
They don't list anything.
December 13 2008, 5:47 PM
Neither does Dennis Carpenter.
Thanks anyway,
Bob
Tom V
(Login thomas11)
receiver / dryer
December 13 2008, 6:04 PM
You can get a dryer from Classic Auto Air in Florida. They repacked mine but cutting it, putting in new dessicant and then welding the tube back together, then painting it. It is done right, but I dont care for the weld line in the middle of the tube. Will probably grind it down and smooth it out to look right. www.classicautoair.com
Tom
(Login bsprowl)
Thanks.
December 13 2008, 7:09 PM
I'll bet that won't be cheap. What did it cost you and when did you get that done?
Bob
Beoweolf
(Login beoweolf)
Is a new/rebuilt Drier required, recommended or optional?
December 14 2008, 12:52 PM
When anAC system is openned, is ti necessary to replace the drier? This is something I have wondered about for years, yet never found a credible answer, based on practical use, facts.
I would assume that an old system, something found at a junkyard for example, which has been open to the atmosphere for 'who knows how long' would be a prime candidate for replacement. What about a system that is cracked open for a motor replacement or repair? Is there a reasonable limit to how long the hoses can be left diconnect before it becomes necessary to purge/drain the system and install a fresh charge/oil and replace compressor, dryer at the same time?
Reason I'm asking...I need to replace compressor (or possibly get away with just changing the clutch). I've been wavering for a few month, now that the cold weather has hit, I find that the heater defroster is not working too. Looks like I might as well combine both - and I'm going to go broke if I have to change everything!
Current Topic - Need a source for a new Receiver-Drier for my '66 Galaxie
