Harland Sharp rocker stand height
December 10 2008 at 6:22 AM
  (Login mbellaire)
HS told me that their rocker stands are 1.375" high on center, while the stock Ford stands are 1.420" high on center. If using HS stands does this difference appreciably change the valve geometry? Anyone had any problems using the HS stands? They don't have the horizontal cut that allows the stand to "grip" the shaft.
(Login MT63AFX)
I ran HS setup on my TP, never measured the stands. Ran 7,600 at .780" lift no............
December 10 2008, 6:25 AM
.......problems. I do recommend using studs and not bolts, JMO, Rod.
FGCofA member #4908
MCGC member #75
Mike
(Login dcmgt)
Each rocker design has it's optimal operating angle, you would need to analyze it
December 10 2008, 6:37 AM
with spreadsheets or CAD to verify whether that height is right.....or just trust the manufacturer, which can be risky.
(Login tbolt2)
Re:
December 10 2008, 10:47 AM
n/c
This message has been edited by tbolt2 on Dec 10, 2008 10:49 AM
This message has been edited by tbolt2 on Dec 10, 2008 10:48 AM
Current Topic - Harland Sharp rocker stand height
