526" SOHC
December 8 2008 at 5:43 PM
  (Login tdm434m)
Didn't do as well as I hoped, but it didn't break after 22 pulls either, RWJ
(Login ScotiaFE)
Ya that will be a real dog on the street. LOL n/m
December 8 2008, 5:58 PM
68 Mustang F/B
67 Fairlane GT
(Login XR7)
looks
December 8 2008, 6:04 PM
like it has double peaks and moves up and down here and there through the rpm range. Something strange going on there, lost 40 HP from 6800 to 7000 and then gained 80 HP from 7100-7200??? 80 hp in 100 rpm?
It is an awesome engine and for one bad ass car, once sorted out I would think it should go into the 7's.
qikBBstang
(Login qikbbstang)
Great maybe we'll hear it at your BBQ. By the way that armadillo on the half shell you all
December 8 2008, 6:14 PM
served up last year was excellent!.................
...................LOL Got to keep the rest of the country on edge!
Jay Brown
(Select Login jaybnve)
Very impressive
December 8 2008, 7:08 PM
Nice numbers, and maybe could have been higher if you'd twisted it tighter; doesn't look like its really ready to fall off yet. Also seems to be pretty rich up at the top end. More power to be had there, for sure...
What is the deal with the big drop in power around 7000? Was the engine missing or something?
What cams are you running in that engine?
Jay Brown
[linked image] [linked image] [linked image]
This message has been edited by jaybnve on Dec 8, 2008 7:11 PM
e. philpott
(Login pooreric)
Re: Very impressive
December 8 2008, 9:02 PM
yes , it looks like if you would have twisted it up to 7700 rpm you would have cracked 900 horsepower
(Select Login ford428cj)
NICE RWJ~
December 8 2008, 9:01 PM
I don't care who you are but that's cool!!! Nice #'s. Thanks for sharing your info RWJ!
"The Poor Mans 427"
1973-1979 Ford Truck Enterprise Link:
http://www.network54.com/Forum/399900
Wes Adams FORD428CJ
64 Falcon X-Ram 428
2000 Yamaha V-MAX VMOA#4277
2000 Yamaha 700 Mountain Max
2001 Polaris 600 Edge X
2001 Polaris 500 SP
Tom P
(Login tomposthuma)
impressive
December 8 2008, 10:31 PM
That's pretty stout!
RWJ
(Login tdm434m)
Dyno
December 9 2008, 4:27 AM
I used this dyno because of the supposed data availabe with it. Sometimes the A/F would work or some other data, then part way thru a pull it would stop reading for no reason. Sometimes the A/F would be 13.3, then 11.9. At least an hour each day was spent fiddling with wires and connections or working on someone else's project while I waited. After I finished the dyno operator said his dyno was 30 HP short compared to eveyone else in the area so I'm not sure how much the the motor could actually make. I did take it to 8000 one time to see if it would break and it didn't have any problems, RWJ
(Login RoyceP)
How about some details on the build?
December 9 2008, 4:36 AM
What kind of heads, block, crank, pistons, cams? That thing is a beast Wayne!!!!
(Login puudog)
Good average hp and torque even with
December 9 2008, 11:09 AM
the drop @ 7000 it could electical or fuel for the reason for the drop, I think fixing the prolems will get you 900 plus on a good dyno and a better average for sure, good job.
(Login BattlestarGalactic)
Great job!
December 9 2008, 7:58 AM
Pretty impressive numbers.
What rockers are you running?
LarryK
1969 F100 428/4spd
1967 F100 352/now a 4 spd!
1959 B Model Mack
RWJ
(Login tdm434m)
SOHC
December 9 2008, 6:44 PM
4.375 x 4.375, Dove heads ported, custom grind cams, 750 lift 334 duration, 306 @ .050, splits with tunnel ram, MSD crank trigger, Ford reworked dizzy by Joe Panek, 14:1 comp. Original Ford non adjustable rockers, never gave me any trouble. No trouble with the ignition, has the steadiest timing I've ever had. Dyno operator said he's seen a double peak HP many times???
Vacumn was 12 1/2 to 15. Jay's vacumn leaks are probably at his dizzy, ask me how I know this. I do have a couple of other pulls a few HP over 890, but none in 900.
I might pull the motor down next year to freshen it and redyno it at a different facility, RWJ
Jay Brown
Thanks for the info
December 9 2008, 9:32 PM
You may be correct about the vacuum leaks at the distributor; it would be a logical place to look.
If you decide to dyno it again, I know one dyno where you could really wring it out wink.gif. Kind of a long drive, but if you're up for it you'd be welcome here. Pick up Barillaro on the way and we'll make it a party...
Jay Brown
RWJ
(Login tdm434m)
Engine leaks
December 10 2008, 5:12 AM
Jay, buy a leak tamer that uses the smoke, one of the best tools I ever bought. I created so much vacum at one point I sucked the rear intake gasket into the engine, RWJ
Current Topic - 526" SOHC
