Fuel octane rating question
December 8 2008 at 8:35 AM
  (Login steveroehrs)
If I were to run an aluminum head race motor with 12 to 1 compression on the street, how much 110 octane race fuel would I have to add to 91 pump premium to eliminate preignition? Steve
Roger Gordon
(Login twistedcrankcammer)
fuel octaine
December 8 2008, 8:42 AM
Steve,
Depends on alot more information then you gave. Stroke affects Detonation. A 12/1 428 will detonate before a 12/1 427. Combustion chamber affects detonation. Engine cooling system affects detonation. Camshaft will affect detonation.
Not a simple one answer question.
Roger
(Select Login Tommy-T)
I ran a 12:1 454 incher....
December 8 2008, 9:01 AM
...quite a lot on the street on 91 octane California "clean air" gas. It had Edelbrock heads and a 308R Comp roller. No audible "ping", but you had to put 'er in gear sometimes to get it to shut off. If you can keep engine coolant temp below 190*, it's a great help.
I wouldn't reccomend any full-throttle "wicks" without "spike'n" the gas 50/50 with some 110.
Bob
(Login machoneman)
Some cool charts here....
December 8 2008, 9:26 AM
but as already stated, many variables exist so no mere table or chart will truly suffice. Best to start with the highest octane one can reasonably achieve and slowly take it down from there.
http://www.daytona-sensors.com/tech_tuning.html
Jay Brown
(Select Login jaybnve)
What are your cam specs?
December 8 2008, 9:43 AM
I put about 7K miles on my 511" FE, with about 12:1 static compression, and ran it all on pump premium. I only added race gas at the track. If your intake valve closes late enough, you shouldn't have to add any race gas to the mix to run on the street.
Jay Brown
[linked image] [linked image] [linked image]
Current Topic - Fuel octane rating question
