This was with a Blue Thunder dual plane intake on my 492" stroker 427, making around 640 HP. I cut away the plenum divider in the intake completely, and then grooved a slot with my mill down the center. Then I made a series of plates to fit in the slot, with different amounts of the plenum divided. Here is a picture of the manifold with one of the plates installed, and a couple of others sitting next to it on a manifold:
I ran the engine on the dyno and tried a variety of configurations, including a spacer under the carb. Results are shown in the following graph:
In my case, a 1/2" open spacer plus cutting the plenum divider down by 1" gave the best results.
You could use this as a guideline for what you are doing with your engine, but truthfully I think you would be better off duplicating what I did with the Blue Thunder intake, and then testing various amounts of plenum divider removal on your particular engine. It seems like your choice of cam, the number of cubic inches, compression ratio, heads and exhaust would all play a part in how effective this mod would be, so the ability to test and tune the different combinations on your particular engine would be the most effective way to manage power optimization.
Jay Brown
