the shift lever on a C-6? I have removed the kickdown lever but not sure how the shift lever comes off. Are they pushed on with a tight fit? I'm putting a Z gate shifter in and the original lever must be removed and replaced with the B&M supplied lever.
Pull the pan and there should be a big nut you have to remove to get the shift shaft out. When you reassemble make sure the tang aligns back with the shift valve in the valve body.
Unless you have specialized tools there is no way to get teh nut off unless the valve body is out. Even with the valve body out, it is not the easiest nut to get on cleanly. Hawkrod
Hawkrod
39 Ford Deluxe Coupe
59 Tbird 430
60 Lincoln Premier
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
86 SVO mustang
76 F250 Crew Cab
1969 Mach I
A floor shift arm is 100 bucks, 66 Tbird is special, Torino/Failrlane column shift is desirable etc... If you going to cut one use one from a pickup or something where they are a dime a dozen. Hawkrod
Hawkrod
59 Tbird 430
60 Lincoln Premier
(2)62 Tbirds
86 SVO mustang
76 F250 Crew Cab
1969 Mach I
hawkrods right drop pan then valve body. if you wrench it it will brake inside trans .please dont cut it off some of this stuff is hard to find and very expensive! we ran that shift on our 70 mach1 d/stock/auto car and yes my dad cut it off!! 1974 era so not rare then but NOW $$$$$$$$$$$$$$$
i know trying to put car on street try finding a kick down lever for a R code mach 1!!!!!!!!!!!!!!
chris
This message has been edited by TA28 on Nov 29, 2008 10:01 AM This message has been edited by TA28 on Nov 29, 2008 10:00 AM
yes some stuff is getting hard to get but what other shift arm are you going to use that is not rare or in need for someone, cut it and be done with it.
