9 inch setup
November 25 2008 at 7:04 PM
  (Login Brandon80)
I removed my carrier to put in a posi carrier. Do I need to check to see if the ring gear is centered on the pinion since I never had the pinion gear out. The way I understand it is to just set the backlash to .008". Any opinions on what I should do
(Login Bad427stang)
If it was good before, should be good now
November 25 2008, 7:49 PM
Just swapping the carrier and setting backlash should do for you.
It may make a little noise if you are a little tighter than it was, but should wear in on a good run.
However, be sure to run a good name brand additive if you have a clutch type posi, and you probably should start with a few slow and gentle figure 8's and circles
- 70 Fastback Mustang, 489 cid FE, TKO-600 5 speed, 3.70 9 inch
- 71 F100 shortbed 4x4, 397 cid FE, headers, Street Dominator, 280H, 5 lug Dana 60, 4 speed
(Login Brandon80)
Re: If it was good before, should be good now
November 25 2008, 7:51 PM
Thanks for your help
Current Topic - 9 inch setup
