Deans (aka Dyno427) Killer Ride!!! WOW must see~
November 24 2008 at 6:35 PM
  (Select Login ford428cj)
"The Poor Mans 427"
1973-1979 Ford Truck Enterprise Link:
http://www.network54.com/Forum/399900
Wes Adams FORD428CJ
64 Falcon X-Ram 428
2000 Yamaha V-MAX VMOA#4277
2000 Yamaha 700 Mountain Max
2001 Polaris 600 Edge X
2001 Polaris 500 SP
I'll post more ~
November 24 2008, 6:44 PM
as soon as Photo Bucket quites screwing up!!!! DAMN thing LOL....
"The Poor Mans 427"
Wes Adams FORD428CJ
64 Falcon X-Ram 428
2001 Polaris 500 SP
Wes Adams Ford428CJ
Here are some more pix~
November 24 2008, 7:30 PM
"The Poor Mans 427"
Wes Adams FORD428CJ
64 Falcon X-Ram 428
2001 Polaris 500 SP
(Login DYNO427)
pics
November 24 2008, 7:53 PM
My thanks to you, Wes for posting the pictures of my "Road Rocket," and yes I do drive it as often as weather permits! No trailer queen here! Again, if it weren't for your posting of the "Poor Man's 427" project, I seriously doubt that this engine would exist today! Many thanks to you for your dedication to FORD, and the F.E. engine! I hope ya'll enjoy 'em!! Dean
(Login winr1)
Very nice Dean!!!..Thanks for posting Wes!!...what has been done to the mill ??..also..
November 24 2008, 8:44 PM
...where can I get some steel painted valve covers like on the first picture ??
Super clean ride....
Richard.
Not a problem Richard~
November 24 2008, 9:10 PM
I'm sure you can get a set of those VC from Dearborn Classics. I have a set just like that from them. Nice set for sure!
http://www.dearbornclassics.com/cgi-bin/more_info.cgi?part_number=VC10B&type=B&year=64&category=ENGINECOMP&keywords=Valve%20covers
"The Poor Mans 427"
Wes Adams FORD428CJ
64 Falcon X-Ram 428
2001 Polaris 500 SP
Tom P
(Login tomposthuma)
Great shot of a marine 427
November 24 2008, 11:02 PM
I think that picture of the painted block can serve as a guide to answer the weekly "I found this 427 and wonder what it's from" questions. It shows the side oiler casting cut away for the motor mount.
What intake is that on the Cobra?
Brent
(Login blykins)
Performer RPM?
November 25 2008, 3:04 AM
n/m
Mike Gaffney
(Login gaffney1951)
I don't think ...
November 25 2008, 8:12 AM
it set high enough for an rpm. Sidewinder? Mike
(Login DYNO427)
intake i.d.
November 25 2008, 8:36 AM
Acording to the guy I bought it from, he said it is similar to the casting # C3AE-9424-E. The ports started out as 2 1/8" tall by 1 1/8" wide. I port matched to 2 1/4" tall and 1 5/16 wide, same on the intake ports on the heads. I really believe that it'll take way more than the 800 cfm carb i'm using!
Myrl Morris
(Login galaxie62)
Great car and motor
November 25 2008, 3:10 AM
That's always been my dream car! What kind of distributor and cap is that?I would like to copy,I have clearance problems with my aircleaner.(62 tri-power)Gal.
Thanks for the great pics!
Myrl Morris
(Login DYNO427)
Dist. cap
November 25 2008, 5:01 AM
That, believe it or not, is the mallory distributor[cable tach drive] that was in the engine when I bought it back! That is also the original mallory marine cap! I just cleaned it up and sprayed it with the same clear w/ prism metalflake[for shows.] I also polished the dist. housing and checked it for performance, since it has no vacuum advance. It has a total advance of 38* @ about 2800 rpm. The mallory cap and rotor are readily available. The dist. model # is YL and the TYPE # is 502-B2. I found a spare dist. on ebay for $25.00, just for parts! Dual point, which is what I am currently using, however I bought a conversion kit for electronic ignition. I just like the "old school" approach to things! Dean
(Login qikbbstang)
Note on those Marine Pentroof Valve Covers....Unique to the Marines I believe
November 25 2008, 6:55 AM
is the Breather Capability/Internal Baffle on Pentroofs that allows filling w/oil and Breather or and /PCV System. The majority of Pentroofs have no such internal baffles and holes for same. Engines w/o get the intake manifold mounted breathers and non-access VCs.
(Login DYNO427)
Pent roof valve covers
November 25 2008, 7:36 AM
You are correct, these each have a baffle inside, and one has the p.c.v. grommet and the other has an opening for a twist in oil breather cap. I prefer the "cleaner look" of no openings. My engine breathes through the oil fill cap/tube and a p.c.v. that screws into the rear base of the carb mount with a hose leading to the rear of the manifold where the road draft tube would attach. Clean-and it works well! Dean
(Login qikbbstang)
Ford secret stuff Re: one has the p.c.v. grommet and the other has an opening for a twist
November 25 2008, 10:34 AM
The VC stamped openings are the same just the rubber (vitton) grommet Avail in Auto Parts Stores or @ FoMoCo twists in to adapt PVC to cover
(Login galaxie62)
Dist.cap
November 25 2008, 6:39 PM
I bought one (crab cap type dist.) off e-bay,I'm going to use it now that I have seen your engine,,,looks great and very "old school".
(Login DYNO427)
ENGINE MODS
Basically, I did a similar engine build as the "Poor Man's 427" project as Wes did! This engine got pulled from a boat about 15 years ago, because of a blown head gasket, which unknown to me, had caused a hydrostatic lock in #5 cylinder, and severely bent the rod!. It was bought very cheap,and sold to a friend who wanted to do a Cobra project. He never got around to it, so last year I bought it back for what I sold it for, 15 years ago!
I wound up sleeving all 8 cyls, and of course had it decked, squared, magged, the usual steps done when taking on a project this size. It's got std. bore 11.6:1 comp. pistons, plasma rings, std. rods and mains. The only parts that were "trick," were the heads [c7ae-a], 428 w/o A.I.R. that I spent personally 50 hours doing the porting and polishing on while the engine was in "repair." I port matched the intake gasket to the intake ports and the intake as well. They weren't flowed, but I tried to make them as close to the same as possible for a "novice." The intake has no Part #'s or production date, but has the FOMOCO logo on the driver"s side. It is aluminum, and was cleaned, and sprayed with a high temp "Chrome Metalflake" show paint[couldn't find a polished or chromed intake,] and then high temp clearcoated, for the shows! It's got an 800 d.p. carburetor, and a Holman-Moody "LeMans Grind" cam and lifters, and lots of chrome or polished aluminum accessories.
I also changed out to a centerforce clutch/pressure plate set-up, [hydraulic] and a freshly rebuilt big in/big output top loader transmission, complete with the correct shifter box and handle. This is a WHOLE LOT BETTER than the small 351-c and T-5 that was in it originally! You can believe that!
Russ
(Login RapidRuss)
Re: ENGINE MODS
November 25 2008, 3:33 AM
My God !! Talk about going from a sows to a Silk Purse !!
Great Job !!
~Russ
"Real Men Dont Own Bowtie's"
Mike Gaffney
(Login gaffney1951)
Nice job ....
November 25 2008, 8:21 AM
just shows what a little persistance and elbow grease will do. Mike
(Select Login 427Howard)
sweet
November 25 2008, 5:10 AM
This message has been edited by 427Howard on Nov 25, 2008 5:19 AM
This message has been edited by 427Howard on Nov 25, 2008 5:17 AM
chrish
(Login kch)
Nice kit
November 25 2008, 2:26 PM
Who's kit is it? It's nicely constructed
chris
(Login DYNO427)
Cobra Replica
November 25 2008, 4:08 PM
Thanks for asking! It is a factory built "roller" or "turn-key minus" built by SHELL VALLEY! They are an excellent company to work with- they helped answer several critical questions during the transformation from a 351-clev to a 427! They also supplied some of the parts, ceramic headers, motor mount plates, and lots of information! The car was delivered without paint, body was removed, and placed on a rotisserie, and 2 bodymen spent 100 hours finishing off the backside of the fiberglass so it looks as good as the top side does! It was basecoated and after the stripes were painted on, it got several coats of clear! Dean
This message has been edited by DYNO427 on Nov 25, 2008 4:12 PM
Current Topic - Deans (aka Dyno427) Killer Ride!!! WOW must see~
