Are 70s 390 truck engines externally balanced?
November 20 2008 at 8:54 AM
  (Login 66gtafairlane)
I found some 390 parts: crank+rods+pistons. Crank is 3U ( = 70s truck)and pistons have a 390 4V marking.
Can I use a standard 390 damper and flexplate with this crank (neutral balance)?
-66 Fairlane 390 GTA.
-70 Torino GT originally 429 SCJ DragPack.
-80 Fairmont Futura Street 393 11,05/ 125mph.
Bobby Spears
(Login x4rdtech)
Yes,I think the 428 is the only one
November 20 2008, 9:23 AM
balanced externally.
(Login pcode390)
Also The 410 Which Uses The 428 Crank
November 20 2008, 10:04 AM
ww
1965 Galaxie 500XL 445ci Stroker (soon) C-6
1965 Galaxie 500XL 390ci P-Code, 4-Speed
1965 Galaxie 500XL 289ci Cruse-O-Matic
2001 Ford F-150 SuperCrew 5.4L
2006 John Deer X320 Garden Tractor
Doug
(Login babybolt)
Re: Are 70s 390 truck engines externally balanced?
November 20 2008, 4:37 PM
Some of the heavy truck FT engines are external balance.
Wes Adams Ford428CJ
(Select Login ford428cj)
NO!!! The only ones are the
November 20 2008, 5:13 PM
391's I do beleave (Heavy Duty Stuff). Otherwise f-100 to f-350 are neutral balanced. 428 never came in PU's but are externally balanced.
"The Poor Mans 427"
1973-1979 Ford Truck Enterprise Link:
http://www.network54.com/Forum/399900
Wes Adams FORD428CJ
64 Falcon X-Ram 428
2000 Yamaha V-MAX VMOA#4277
2000 Yamaha 700 Mountain Max
2001 Polaris 600 Edge X
2001 Polaris 500 SP
Current Topic - Are 70s 390 truck engines externally balanced?
