oil pump
November 16 2008 at 4:00 PM
Len  (Login katfreek68)
What`s the deciding factor in going to a high volume oil pump over a standard volume pump?
Howie
(Login ScotiaFE)
Re: oil pump
November 16 2008, 4:30 PM
Here are all the FE Pump specs for everybody
M-57 STD Volume Yellow Spring (40-45psi Idoit lite Bad) 1/4" Drive
M-57B Std Volume Brown/Plain Spring 60-65 psi 1/4" Drive
M-57HP Std Volume Big Blue Spring 100-110 psi 1/4" Drive
M-57HV High Volume Brown/Plain Spring 60-65 psi 1/4" Drive
M-57A Std Volume Brown/Plain Spring 60-65 psi 5/16" Drive
M-57AHV High Volume Brown/Plain Spring 60-65 psi 5/16" Drive
Doug aka pumpbldr
Precision Oil Pumps
Thanks Doug
See links at top of the page for Dougs site.
Mininum you should use is the M-57B
The M-57HV pump can be used with no problem.
A ARP drive shaft is a must have.
A high quality pan and windage tray is a must have for any serious build.
(Login katfreek68)
oil pump
November 16 2008, 4:53 PM
Good info Howie. Doing a moderate rebuild on my 390 and was wondering what to do about the oil pump.
(Select Login 427Howard)
WRERE
November 17 2008, 6:35 AM
can i buy these high psi springs??
(Login diesel_god29)
Re: oil pump
November 17 2008, 10:37 AM
I have a ?tion about high volume oil pumps ?
there not like electric water pumps that are really only good for track purposses only .
I have a ford 332 that i am building a 410 stroker out of . would u say go with the high volume oil pump at this point ?
and the rest of the ?tion is if u had a high volume oil pump and didnt need it would u run oil to fast for it to cool parts . prolly a dumb ?tion
Current Topic - oil pump
