Motor Plates?
November 15 2008 at 4:57 PM
  (Login 2bolts)
At what HP / weight do drag race door cars need or require motor plates and why???
Thanks, Jim
(Login gbagitator)
jmo
November 15 2008, 5:37 PM
I think it has to do with motor set back in a modified frame. In a stock pos the motor mount is set over or close to spindle & crossmember to avoid chas twisting. Dont know the rules Gord
dedom
(Login dedom)
Motor Plates
November 15 2008, 6:03 PM
I don't think it has very much to do with wt/HP as a requirement but more with class specific rules wether or not motor plates are allowed.
JMO
(Login 2bolts)
Motor Plates?
November 15 2008, 6:14 PM
I'm pretty sure most anything goes in that area for NSS or AFX?
(Login Posi-67)
Probably help stiffen the chassis/frame
November 15 2008, 7:19 PM
some, but unless you need to remove or modify the original mounts for header clearance, I personally wouldn't go to the trouble. Are you planning on hopping up that car soon??
(Login blueoval67)
It all depends....
November 15 2008, 7:26 PM
motor plates are used for a few different reasons. They can be used to relocate an engine to a better position for improved weight transfer. They make it easier for big tube custom headers to be used since there are no motor mounts. They allow an engine to be installed in a chassis that normally wouldn't accept it. They also tie the engine to the chassis better in high horsepower situation. There is no magic formula that says when you should use a motor plate but I would use one if your car runs 9's or better and I wouldn't run one in a street car unless it runs 9's or better. Hope that helps to answer your question.
Dave Walters
427 Galaxie Registry
Website
http://home.ptd.net/~pwalters
RWJ
(Login tdm434m)
Motor Plates
November 16 2008, 5:25 AM
Dave got it right on all points. They generaly speed up access to the engine for installtion, removal and maintence of everything, RWJ
Current Topic - Motor Plates?
