Good running 69 CJ, car has been sitting for 4 months is there anthing
November 11 2008 at 9:53 AM
TonyS.  (Login TS69GT500)
I should do before attempting to start it up again?
I don't want to do any damage, always willing to perform some overkill to be on the safe side.
Thanks,
TonyS.
This message has been edited by TS69GT500 on Nov 11, 2008 9:54 AM
(Login oldfordman)
Sitting Cobra
November 11 2008, 11:01 AM
I have let mine sit for as much a 10 months. Only keeping the battery charged.
1: Don't set your parking brake when you park it for a long time.
2: Spin it over enought to get oil pressure up before you try to get it to start. ( hopefully you have a guage )
3: Make certain nothing has leaked down when you start to start. (trans, water, and other fluids)
4: Go have fun when you do get it started. If yours is like mine it will be one honery son of a gun at first ( not wanting to idle ). Get some fresh gasoline in it quick.
Have fun
Paul W
(Login ERA428)
Before startup
November 11 2008, 2:33 PM
Tony The motor should be OK but I would remove the sparkplugs and spray some WD-40 in each hole. Crank the motor over without the spark plugs in and get good oil pressure. Does the gas has a stablizer in it? Remove what gas you can and put some fresh gas in the tank. Block off the fuel line to the pump. You don't want gas to go into the motor while you are just cranking it. After you get good oil pressure, install a new set of sparkplugs, (check the gaps) Hook up the fuel line and crank the motor. Don't start it until you have fuel in the carb. Pump the pedal to set the choke. It should fire up. Let it high idle until it reaches operation tempature. Go for a short drive around the area. This will get all the lubercates in the trans and rearend going to the right places. When you get back, change the oil and filter with new stuff. You should be good to go. I would also get a bottle of Lucas oil suppliment to add to the motor. It's a clinging motor oil that helps stop dry starts. Pour this in slow with the new oil being warm. You will need to run the car for this. It stops noisy lifters and rockers. Rick Lake
Current Topic - Good running 69 CJ, car has been sitting for 4 months is there anthing
