Steel Fuel Line
November 4 2008 at 12:00 PM
  (Login cyclone03)
I want to run a 1/2" fuel line from the tank to carb in my Mustang but I don't want to run flex hose front to back.
I also don't want Aluminum.
I got a short piece of 304 stainless from work with .028 wall to see if my flare tool would work with it with no luck,it's too hard.
Does anybody know of a source for 1/2" tubing like the steel sticks they sell at the parts stores in 3/8,5/16,and 3/16"?
The parts counter guys checked there suppliers with no luck.
Maybe even a source for "softer" stainless?
SSdynosaur
(Login SSdynosaur)
Tubing
November 4 2008, 1:08 PM
Classic tube, www.classictube.com, advertises that they sell "annealed" stainless tubing, however I don't know about the 1/2" size.
Barry R
(Login Barry_R)
I can get it here in Detroit
November 4 2008, 1:52 PM
I just don't know how to ship a 20 foot stick.....
Barry Rabotnick
Survivalmotorsports.com
(Login cyclone03)
Where do you get it from?
November 4 2008, 2:02 PM
Or do you have a brand name on the tubing?
(Login 391locker)
Re: Steel Fuel Line
November 4 2008, 2:51 PM
McMaster has steel tubing in a wide variety of diameters and 6' lengths.
(Login johnvermeersch501)
Check the weight of the fuel
November 4 2008, 3:53 PM
that will be in a 1/2 line X 20ft ????can your pump push it forward during a 3G launch???There is a reason old S/S racers used 2 peices of 1/4 line from the tank !!!!
(Login qikbbstang)
John I'm surprised you made that statement...... Had a customer in maintenance that went
November 4 2008, 5:09 PM
ballistic on a Purchasing Agent that got him two 2" Valves when he requested a single 4" valve because she could not get a 4".
Two 1/4" lines hardly could be considered to flow equal to a 1/2". Ive always wondered why folks don't run smaller sized lines and put the pressure to them. Sure a 1/4" line might not flow enough for a 500HP motor at 6-7PSI but at 15-20PSI???
(Login cammerfe)
Not likely that you'll need....
November 4 2008, 7:33 PM
1/2 capacity. 2 X 1/4 will supply all you need.
KS
Kyle
(Login 1966Tbird)
could you do that?
November 5 2008, 12:28 PM
i've never thought about that but i think it should work if you adjusted your floats. as long as you adjust your floats could you run more pressure than 4-7psi
(Login Bullitt406)
You would install fuel pressure regulators before the carb or carbs n/m
November 5 2008, 4:04 PM
(Login FE4RD)
Any local industrial/hydraulic supply dealer...n/m
November 4 2008, 5:00 PM
n/m
(Login JA428FE)
Try Annealing it
November 4 2008, 8:25 PM
Heat up the end till it glows red then let it cool down. It should flare then. John
1970 Land Cruiser, 351w, NP435
(locked up front and rear)
1965 Galaxie, 428, C6, 3.89 gear,
Detroit locker
1979 Spectra Day Cruiser
stock 350ci Brand X, Mercruiser..53mph on GPS
This message has been edited by JA428FE on Nov 4, 2008 8:26 PM
(Login cammerfe)
Or braze steel fittings to the ends, if....
November 5 2008, 10:21 PM
you feel you need 1/2 inch.
KS
Current Topic - Steel Fuel Line
