are custom,I will take credit for the design, but they were built by my body shop. My goal was to make them look as stock as possible while at the same time giving me enough room to change plugs. If you noticed the top is stock, we came down maybe 3/4" and started cutting back as close as possible to the stock spring. Then went straight down to just above the top A arm then came right angle out. I had a metal shop bend a piece of 12" square 1/4" plate steel at a right angle 1 1/2" from one end. My body shop man made the roll at the top and fitted it, trimmed it, welded it in, mainly from the spring side, then grinded and filled till it looked factory.
I have since installed a Ron Morris coil over front suspension, thus no shocks poking thru. The radiator hold down is stock, I had it ceramic coated. The radiator is a Griffin aluminum that is made for the Mustang. Thanks for the compliments.
Craig Mitchell
68 Mustang GT 428CJ
