Smoking Fe
October 29 2008 at 10:47 AM
  (Login Boaterbob)
Pulled the rockers off and put a Holley jet drilled out to 3/32 in the hole. Started the engine and the oil comes over the edge of the head pretty quick. Checked out drain holes seem to be fine. So is it normal for the oil to over flow or maybe i need a smaller restriter?? I don't know exactly how much oil hould be coming up. Thanks
SMOAK
(Login PREMOD70)
Two things I would consider..
October 29 2008, 10:55 AM
would be the clearance of the rocker arms on the shaft(leakage) and possibly running a thinner viscosity synthetic motor oil for faster drainage.
(Login WarrenD)
And I would also check
October 29 2008, 11:06 AM
To make sure the rocker shaft holes are facing down. I had a size #60 holley carb jet in my heads and it worked pretty good. I cut the tops out of an old used set of valve covers and put them on to observe the flow so I wouldn't have a mess. JMO Warren
As stated above, rocker arm/ shaft clearances are critical in this area too.
68 Torino GT S code 390 fstbk
70 Torino GT 351cl 4spd
71 Torino Cobra 429 C6
Bob
(Login machoneman)
Agree....
October 29 2008, 11:13 AM
that a smaller i.d. restrictor may be required. I'd also ask just how old those valve seals are as well. If in good shape, limiting the oil flow may be the ticket. However, if they are old and cracked, especially the OEM Ford black rubber/viton type, you will still get oil smoke that will eventually get progressively worse.
Bob P.
(Login Boaterbob)
Re: Agree....
October 29 2008, 12:02 PM
Thanks, I'll try a smaller resricter. How do you check the rocker to shaft clearence? Don't know much about the engine since i bought the car used, It was supposed to have been rebuilt not to long ago. It does have solid lifters. Bob
(Login WarrenD)
Well, you need a decent set of digital dial Calipers to check
October 29 2008, 4:21 PM
The inside diameter of Each removed rocker arm and then check the outside diameter of the rocker shaft. The difference between the two would be your clearance. I am not sure what is allowed for clearance at the moment without looking it up.Someone may chime in with this info. Don't check just a few, checkem all. This way you will know. If rocker shaft looks worn as well as rocker bushings, might think about replacing both. Also when checking your valve seals, check them all and see if any of them are riding up with the valve and not staying down on the valve guide boss. If they are riding up this will allow oil to get into guides and cylinder thus burning.
JMO Warren.
This message has been edited by WarrenD on Oct 29, 2008 4:26 PM
This message has been edited by WarrenD on Oct 29, 2008 4:25 PM
Royce
(Login RoyceP)
If you are using umbrella seals you need to use the factory drain tins
October 29 2008, 12:01 PM
Like these:
Bob P.
(Login Boaterbob)
Re: If you are using umbrella seals you need to use the factory drain tins
October 29 2008, 12:50 PM
Thanks Royce, Factory drain tins are in place
mikee
(Login mikeelikee)
Don't just look at the drain holes
October 29 2008, 12:46 PM
probe with a piece if wire. Old pieces of seal will jam in there nicely and mat not be seen. A pick and a shop vac work wonders.
Current Topic - Smoking Fe
