tranny trouble?
October 23 2008 at 4:30 PM
  (Login hemiabone)
im having trouble with my trans in my truck.when i try to bring the rpms up it dont shift out of second gear.i've checked the modgeulater its not leaking.when i drope the rpms it will shift out of second.got any ideas what the problem is.
(Login Rhillebrand)
Re: tranny trouble?
October 23 2008, 6:21 PM
Check the operation of the kickdown rod. Make sure it is working freely and the spring hasn't broken. Check for vacuum leak at the tree where the modulator vacuum hose connects to the manifold. A modulator valve doesn't have to be leaking to be defective. It may be sticking. You may have to remove it and check with a vacuum pump for proper operation.
If all of those things are ok you may have a sticking governor. You may have to remove it and check the counterweight springs for proper operation.
This message has been edited by Rhillebrand on Oct 23, 2008 6:21 PM
e. philpott
(Login pooreric)
wich transmission ???.... and what year is it ??.nm
October 23 2008, 6:33 PM
nm
(Login hemiabone)
re:tranny trouble?
October 23 2008, 11:29 PM
i have a c6 in it.i took it out of a 1970 ford ltd wagon.i dont have the passing gear rod hooked up.
Tony
(Login playerT)
check here
October 24 2008, 5:49 AM
Current Topic - tranny trouble?
