Date code question
October 22 2008 at 8:44 PM
Barry Byer  (Login BarryByer)
I just picked up a C4AW-B non "N" nodular case with the date 8K15. That one isn't a problem, the problem is the C5AW-4668-C pinion retainer that came with it. The date code I see is either I19 or 119 it's hard to tell.
The guy I got it from said it was from a '69 Boss 429. I suppose it could be with that date code on the case but the pinion retainer is a mystery to me...
Photobucket
53 F100, Volare clip, 4 wheel disc 390-wide ratio toploader
(Login GJCAT427)
I always thought that that the" I " wasn`t used,,,,,
October 23 2008, 3:39 AM
in Fords date coding, but that sure looks like one to me. First time I`ve seen that on any part, Maybe Hawk can clear it up.
Dave Walters
(Login blueoval67)
Is this a "SPEC" case Barry?
October 23 2008, 6:38 AM
That date code is interesting. I didn't think Ford used "I" at all in the date coding due to the confusion with using the "I" and the "1" together. Hopefully Hawkrod will chime in.
Dave Walters
427 Galaxie Registry
Website
http://home.ptd.net/~pwalters
Barry Byer
(Login BarryByer)
No, the part number is clear.
October 23 2008, 8:07 AM
C5AW-4668-C but the first two digits are different. The middle is definitely a "1" but the first digit is different. I've never seen Ford use an "I" in date codes either.
The date code on the case is also very clear. No "SPEC" anywhere.
(Login trossol)
I don't know what it means, but
October 23 2008, 9:00 AM
I have seen this on a couple Daytona pinion supports before.
Pippin
(Login TorinoBP88)
maybe built on Friday the 13th or April Fools day, LOL, Ive never seen that cope. But
October 23 2008, 10:58 AM
and i supposed to read that as September 1, 1969?
1968 GT/CS Mustang. 289/c4
Another Galaxie (one day.)
Tom P
(Login tomposthuma)
I can clear that up
October 23 2008, 11:27 AM
Barry, i'll be over shortly with a crisp new twenty dollar bill to take that problem from your hands.
Barry Byer
(Login BarryByer)
It better say "In god we trust"
October 23 2008, 12:48 PM
I ain't taking those Canadian pesos anymore!
(Login BarryByer)
I kind of thought Hawkrod...
October 23 2008, 12:50 PM
Would be able to clear this up. Oh well, it was cheap enough that it can live under the bench for a while.
Current Topic - Date code question
