Help!! Have FE camshaft question
October 22 2008 at 8:13 PM
  (Login freakyfordluvr)
First off, I am not at all mechanically inclined, so I need opinions from any of the wonderful posters on this board. I am wanting to add an hydraulic camshaft & lifters only for my '69 390. Engine has stock heads w/ factory arms, headers, Holley 670 and a worked Powermaster intake, toploader and 3.25 gears. I'd like an aggressive, choppy idle but without any vacuum issues. Street engine will never see 6000 rpm. Any opinions on lift and durations and manufacturers? Thanks!!
(Login 66FAIRLANE)
How many rpm are you prepared to have it see?
October 22 2008, 10:14 PM
How many miles on the motor?
This message has been edited by 66FAIRLANE on Oct 22, 2008 10:15 PM
Pippin
(Login TorinoBP88)
what car? Biggest id go is 270S, but you said hydraulic so 270H
October 23 2008, 5:24 AM
I would not go split duration because they usually loose off idle torque unless it is small like a XE262, those are all Comp Cams grinds.
Crower has some close lobe center small cams also.
3.25 gears will make the choice tough because too big a val and you will go SLOWER and use more gas.
All the aftermarket cams are choppier then stock because stock has lobe separation of about 112 or 114 even 116 on some 2v grinds... so most aftermarkets are at 110 lone separation this make the exhaust not choppier.
Now a 280H grind will sound great, but..... i would question the 3.25. The 4 speed will make it a little better though.
1968 GT/CS Mustang. 289/c4
Another Galaxie (one day.)
(Login werbyford)
5 cams and some numbers
October 23 2008, 8:41 AM
I ran your engine thru the Gonkulator since I wondered mainly about straight pattern vs dual pattern. Since your exhaust flows pretty good relative to the intake my bet was closer to straight pattern, and though there is a lot of "magic" in the computer on this point, the Gonk favored a straight pattern or nearly such - it wanted exhaust duration only a couple degrees more than intake, or even equal.
I installed all the 5 cams below 4 degrees advanced.
I took the average of peak torq and power or (T+P)/2 and got:
390gt cam, 207-221-116-.481-.490
(T+P)/2=381
204-214-112-.484-.510 cam:
(T+P)/2=382
Elgin 1048p, 218-218-112-.528-.528
(T+P)/2=393
Torq 415 at 3700
Powr 373 at 5200
SSI 223-223-112-.513-.513:
(T+P)/2=393
Torq 410 at 3800
Powr 376 at 5200
Comp 270H, 224-224-110-.528-.528:
(T+P)/2=396
Torq 409 at 3800
Powr 383 at 5200
I kept the lift of all the cams low enough so that hopefully the stock rocker assy is up to the task.
The Comp 270H would have the most "rump" due to its overlap and also gave the highest numbers, but would cost more than the Elgin or SSI. Pippin also liked the Comp 270H so I think any of the last 3 cams are approx what you want.
What is the car and its use?
robert watkins
great responses!
October 23 2008, 7:19 PM
Thanks guys! The 390 is original to my '69 Mach 1. Engine was rebuilt about 7000 miles ago and runs strong. BTW I said Powermaster intake, I meant Streetmaster. Just needing it to sound good, maybe a few more horses, don't care so much about top end. I am considering a later change in my rear gears to around 4.11s.
Current Topic - Help!! Have FE camshaft question
