timing chain covers
October 14 2008 at 9:11 AM
  (Login rubeck)
What is the diffrence between a 65 cover and a 68 cover with one small screw and one cover bolt the 65 has two small screws? are the pointers in the same place?
(Login hawkrod)
The difference is the pointer. The later cover was redesigned for a bigger pointer
October 14 2008, 9:41 AM
The pointers are in the same location and you can use an early pointer on a later cover or a later pointer on an early cover (but you need to make a spacer or drill an extra hole). Hawkrod
Hawkrod
39 Ford Deluxe Coupe
59 Tbird 430
60 Lincoln Premier
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
86 SVO mustang
76 F250 Crew Cab
1969 Mach I
Current Topic - timing chain covers
