Getting all the oil out is a big problem. Cascade dishwaser soap or dawn dish liquid is the best I've found. Years ago I had a BB scrub with this problem , and it took quite a few cleanings till I got all the oil out.
Oil floats to the top and adheres to everything, it take a grease dispersent to remove it. If you can run water with the soap it works better than a water antifreeze mix.
Just some thoughts--- Fergy |
