Royce, I'm sure you are correct about the dual plane 2X4 intake. I'll bet that engine will pick up 20+ HP with that setup. At peak power I was pulling 1.4" of vacuum with the Performer RPM and the single 4150 HP carb. Anything over 0.6" or so is leaving power on the table.
I wish I had a set of the new Blue Thunder MR heads. About a year ago I talked to A.T. Francis at Blue Thunder about my intake testing, and he asked me about a head comparison also. We talked about this for a while, and settled on doing a head comparison where I used the same valves, did the same amount of porting work, and compared the Edelbrock heads to the BT MR heads on the dyno. He volunteered to send me a set of heads for this purpose, if I covered the expense of the valves, porting work, assembly, and testing.
I had a set of bare Edelbrock heads already, so I bought two sets of 2.19/1.72 valves for both pair of heads, then took one set with the Edelbrock heads into my shop and had them street/strip ported. These are the heads that are on the 427 I'm currently testing. Then I waited for the Blue Thunder heads. Unfortunately, I am still waiting. I've called BT a couple of times on this, but have had to leave a message, and have received no response. Maybe he forgot, or changed his mind, or something...
In any case, at some point I'll probably buy a set and run the head comparison test. But I have lots of Edelbrock heads here, so for now all my testing will be using the Edelbrock heads.
Jay Brown
