Common side oiler newby mistake
December 21 2008 at 6:01 PM
  (Login RoyceP)
Response to Another SOHC Engine Failure !!!! Warning
I had a similar problem caused by a Crane cam that had the oil groove ground in the cam too far forward. Same remedy, we ground the groove wider to compensate.
Like Jay said, you should always pre - oil any freshly assembled engine and witness oil flow from each rocker, or suffer this sort of consequence for not doing so. A side oiler has a couple extra "gotchas" that the average machine shop is probably unaware of. Heck, any FE is a mystery to the average shop nowdays.
