Jay I am sorry to hear about the problems that you have had. I knew going into this deal that Larry would help us get it right I just hate that you have had some problems. I feel that when Larry gets the changes that you and he have talked about that we will have a good peice for a change. I feel if they will hold up on your combination they will work on most everything else.
I talked with Bill Koon and he told me about the rocker seizing on the shaft problem and what he thought could be done to fix it. When I talked with Larry at PRI he talked like they had tested the adjuster pretty well. I am glad that they could duplicate the problem you were having and will be getting more adjusters. I will be sending the sets I have back and getting all of this taken care of so that we will have some of the new stuff available.
I guess this valvetrain is just a little different in a few areas than most. Glad that you have been able to help Larry get this figured out so that we will have a good rocker arm assembley available. Good luck on your projects and let me know if I can help in the future. I would like a chance to do some work for you in the future.
On another subject I think it would be neat to try some of the BeeHive springs on the cammer heads. Seems like a real good application for them.
