Tire info
December 19 2008 at 8:59 AM
  (Premier Login fairlaniac)
Response to Options
Thanks for the tire info. I was looking at the Hoosier 28x9x15 that you mentioned in your reply
"Hoosier 18140 28.0/ 9.0-15 9.0" 28.0" 88.0" 8-10" 8" 11.1" D06
Phoenix 9.00/28.5-15 PH377 F9 8.0 12.5 28.6 8.9 25.0 90.0
M&H 9.0/28.0-15 MHR-70 #704 9.0 11.0 88.0 8.0
Lots to pick from, various heights. All should fit fine on a seven-inch wheel, and have lots of clearance with the spring and fender.
Wheels are pretty reasonable"
The Hoosier cross section is 11.1, so you're saying tha twill fit on a 7" wheel? I know what the manufacturer recommends and wha tactually works are two different things so before I get some Hoosier 18140 tires, have you ever fit these on 7" wheels?
Thanks,
Doug Bender
1966 Fairlane 390/428CJ Heads, 4-Speed
