Clearance specs
December 18 2008 at 4:33 PM
  (Login babybolt)
Response to bushings
I have not seen the Ford rocker specs on the Cammer, but on the Boss 429 the rocker arm to shaft is .002/.004. Side clearance is .001/.016. These upper limits seem pretty loose. The Boss 429 uses the same bronze type of bushing in a forged rocker and the shaft has the same oil hole and cross slot as the bottom of the Cammer rocker shaft.
