| Pipe vs. tubingDecember 17 2008 at 10:06 AM | Phil Swenson (Login CobraPhil) Members |
Response to O/T Pipe Bender |
| Keep in mind that the pipe bender is made for water pipe, etc. They will not bend tubing, such as exhaust, roll bar tube, etc. without kinking it due to the different exterior diameter. If you want to bend tubing, look at the benchtop one from Speedway. I use a air hydraulic one from Mittler Bros., but is much more expensive. I bought the HF one and tried it on a 2" water ski bar for a friend's boat...did not work worth a hoot. PHIL |
| Responses |
