Dyno runs---
December 9 2008 at 6:12 AM
  (Select Login MsgtJoe)
Response to 585 SOHC on the dyno
Jay, do you use any air filters for your dyno runs? Do you use any kind of beveled/radiused inlet for your throttle bodies? You may have a simple problem with air turbulence if you are not using any type of duct/filter/radiused inlet. With twins, you need to separate the distance so as to not cause airflow starvation problems. Just an observance. Joe-JDC.
