On SB Fords, the crankshafts flywheel bolts are open to the crankcase, in other words if the flywheel bolts are installed without some type of sealer or Locktite, oil can wick thru the threads of the flywheel bolts & leak oil onto the clutch, or drip out of the bottom of the bellhousing. Worth taking a look at.
74 F350 ramp truck 390 4speed
