One way:
December 6 2008 at 10:36 AM
Bob  (Login machoneman)
Response to Pull the plugs
http://www.network54.com/Forum/74182/thread/1213704438/Smokin+FE+-+Details+about+crank+test
Also, see "pressure leak detection" section below and use air pressure to the intake side. If you use this method, best bet is to pull the rocker shafts or back off all open intake valves. Must also block all vacuum lines going into the intake. Making a simple alum/steel/wood "plate" to block off the carb pad is also required.
http://www.aa1car.com/library/vacleak.htm
This message has been edited by machoneman on Dec 6, 2008 11:00 AM
This message has been edited by machoneman on Dec 6, 2008 10:51 AM
  • Smokin` FE - Rory McNeil on Dec 6, 2008, 12:02 PM
