Start up
November 27 2008 at 9:00 PM
  (Login coogs)
Response to it should run fine at .018
If you got a nice blue spark from the coil wire? CK for 180 out
or firing order. 15426378
If no blue spark, you got problem in coil/distributor. Any carbon tracks
in the cap? Coil wire, good? Pull coil wire from dist cap and hold 1/4"
from nearest ground. Crank over with solenoid. Observe spark. Blue $ nasty
looking? KOEO. Just some things to look at.
Good luck, Coogs
