Search:
Login
Register
Home
Forum
Classifieds
Archive -
Photos
Tech -
Events -
Links
9 inch setup
November 25 2008 at 7:04 PM
Brandon
(Login
Brandon80
I removed my carrier to put in a posi carrier. Do I need to check to see if the ring gear is centered on the pinion since I never had the pinion gear out. The way I understand it is to just set the backlash to .008". Any opinions on what I should do
If it was good before, should be good now
- Ross on Nov 25, 2008, 7:49 PM
Re: If it was good before, should be good now
- Brandon on Nov 25, 2008, 7:51 PM
$1.00
$2.00
$3.00
$4.00
$5.00
Other Amount
