New bearing break-in
November 6 2008 at 9:29 AM
  (Login gwittman)
Response to http://www.stp.com
I use something similar to STP (Motor Honey) when I rebuild and engine. I wipe a thin film on the wear face of rod and main bearings to provide initial lube until oil pressure builds up. I rotate the engine a lot by hand during assembly to help wear in the rings, so the STP like film prevents damage to the bearings. I also put it on the cam wear surfaces during engine assembly.
I rebuild a race engine almost every year for over 20 years and it has worked well for me. However, I have heard that adding it to the oil in and engine does cause a lot of sticky sludge.
