galaxie discs
November 4 2008 at 6:07 AM
john tolliver  (Login jwtdvm)
Response to 1964 Galaxie disc brakes
ny galaxie thru at least 72 is direct boltlt on with the corresponding spindles---may need tie rod end that goes with new spindle--68 and later has single piston (cheap and readily available) caliper and 66-67 has 4 piston ( expensive and difficult to find) caliper--be fore warned-the 70-72 wont fit your wheels--the hole in center not large enough--not sure on 68 and 69 may be the same problem--either get the wheels with the donor car or after market mags etc will usually work
