the "other" lifters ( for motors that oil thru the pushrods) your pushrod length should have been WAY off..like a .100 off, did the adjustments come into the normal location?? It really should not be a problem, if the oil supply is plugged, the lifter will work the same as a std. FE piece. I would revisit the adjusting screw, and RA geometry.. |
