mock-up
October 30 2008 at 3:07 PM
  (Select Login MsgtJoe)
Response to Aluminum rod block set up?
Find the compressed thickness of the head gasket you are going to use, and subtract that from .060", and that will tell you how far in the hole your mock-up must be(usually .040-.041"). If it is not down .020" @ TDC, then you will need a .060 compression thickness gasket available from Cometic. Joe-JDC.
This message has been edited by MsgtJoe on Oct 30, 2008 3:09 PM
