| took another lookOctober 26 2008 at 7:19 PM | fakesnake.com (Login fakesnake.com) Members |
Response to Look inside the carb.... |
| I looked inside the carb (stock 2 barrel) and when pulling back on throttle you can see both sides squirt gas into the bowls. There is a ring protuding over each bowl. The gas squirts below it into the bottom.
I also moved the shaft up and down (vertically) from driver side and there is some play. Each time I do it you can see gas and air seeping through the spot I mentioned on passenger side. |
| Responses- Likely.. - BattlestarGalactic on Oct 27, 2008, 5:30 AM
