Re: 391?
October 26 2008 at 5:50 PM
  (Login 767Jockey)
Response to 391?
I'm far from an expert on this forum, but I almost did this myself. What I remember from it is that the FT block is virtually identical to the FE except for the distributor shaft housing diameter. The FT shaft diameter is larger than a normal FT housing diameter, but there are bushings readily available to bring this diameter down to standard FE diameter. Again, check on this info for accuracy but if memory serves me accurately this is the only difference between the 391 FT block and an FT block.
