Click logo to enter advertiser sites
C1SP-7976-A
January 23 2008 at 12:12 AM
  (Login 1968_Falcon)
from IP address 198.53.189.30
Aluminum Thunderbird mx bell?
If anyone has this FE Bell Loose could you please set in on a flat surface engine side down and measure the depth from the transmission mounting surface to the engine mounting surface and the ID of the 'big hole' on the back.
Many thanks,
John
John Johnson BEng
1968 Falcon Futura Sports Coupe
460 Test Mule C6 3.70:1
Under Construction
(Login 1968_Falcon)
198.53.189.30
C5AP 7976A - FE / FMX Bell
January 26 2008, 12:40 AM
If anyone has this bell, that's a ditto here too.
J
160.128.17.5
C5AP 7976 A
December 17 2008, 1:53 PM
I have this same bell housing. I am still trying to identify my engine and transmission and so far, nowhere can i find a C5AP-7976-A. its strange... lots of B's..... any ideas?
Nate
(Login tbolt2)
207.69.137.26
Re: C1SP-7976-A
January 30 2008, 12:52 AM
C1SP-7976-A
Pilot bore dia = 5.878" - 5.876"
Length = 7.253" - 7.248"
Dennis
(Login 1968_Falcon)
198.53.189.30
AWESOME!!
January 30 2008, 4:51 AM
Thanks!!
J
John Johnson BEng
Under Construction
(Login stuart40a)
Forum Moderator
142.165.145.207
that stuff
January 30 2008, 10:22 AM
(Login tbolt2)
4.229.45.169
Re: that stuff
January 30 2008, 3:46 PM
What I posted were not measurements taken off of a housing, but are the actual print dimensions.
Dennis
This message has been edited by tbolt2 from IP address 207.69.137.14 on Jan 30, 2008 3:51 PM
(Login 1968_Falcon)
198.53.189.30
print dimensions?
January 30 2008, 4:35 PM
Where do you get print dimensions?
Do you have them for other bell housings?
Would you like me to pay part of the cost to scan them in to a computer so they can be shared?
Kind Regards,
John
(in this case are the C1 and C5 Bells the same?)
John Johnson BEng
Under Construction
(Login 1968_Falcon)
198.53.189.30
that stuff can not...
January 30 2008, 4:55 PM
mmerlinn is a great contributor to Ford Transmissionology (not a word - don't care). I reviewed his work before i asked. The page you recommended is a C4/C5 page. I would like to see one as complete for FM/FMX/MX transmissions as those are the bellhousings i am asking questions about.
It is my intention to adapt an FE-FMX Bell to the front of a C4, a C5 or an AOD (Just watch me!) to jamb the works into a mustang II or some other lightweight.
I'm not into paying $500 for an FE to C4 conversion bell if i can scrounge an MX/FMX bell and turn an adaptor plate myself. I'll post pictures when i'm done.
John Johnson BEng
Under Construction
(Login stuart40a)
Forum Moderator
142.165.145.207
Re: that stuff can not...
January 30 2008, 5:14 PM
I have no doubt whatsoever you can do what you planned.
I myself have installed a C4 onto a Toyota engine.
Why not adapt a C4 bell housing?
(Login 1968_Falcon)
198.53.189.30
Hard to center the bell.
January 30 2008, 5:51 PM
You have a valid point. I felt this might be easier.
I thought about using a C4 small block Bell onto the Back of an FE with an adaptor plate but it's a whole other challenge to get the two sets of dowel pins located correctly with respect to each other and the crankshaft/input shaft..
The FMX bell is already located by dowel pins to the block which in turn locates the transmission concentrically at the pump to the crankshaft. It's a given that the indexing hole in the bell is located concentric to the crank. I have to do very little work to make a plate correctly at that point.
Unless you have really good drawings and i do a CAD thing to send to a CNC shop (and get the 4 dowel pins right) after hours i think the other approach is much more frugal.
Further, I require a smaller piece of stock material. To get the two centers set up i can turn the stepped wafer shaped adaptor plate on a brake lathe or give it to a high school kid in metal shop class or something else low tech. Once i have a stepped ring the right thickness i can transfer the bolt holes with transfer punches and i'm done.
It will come out of the lathe with an excessive OD to pick up the furthest FMX pattern bolt but then i'll trim off what i can't use or don't need. It's a $100 answer instead of a $500 answer.
That's why..
John
John Johnson BEng
Under Construction
(Login stuart40a)
Forum Moderator
142.165.145.207
here is a ready made plate
January 30 2008, 11:03 PM
[IMG][/IMG]
I'm not sure if you have seen one.
This message has been edited by stuart40a from IP address 142.165.145.207 on Jan 30, 2008 11:09 PM
(Login 1968_Falcon)
198.53.189.30
Yep, Sure have
January 31 2008, 1:12 AM
http://www.transmissioncenter.net/c4_c6.htm
Right here.. Same Picture, $695 + shipping.
Wrong way - thanks, but no thanks.. unless you have a spare you would like to donate.
I want $100 or less... I'm pretty sure i can do it too. My cost will be lower than the scrap weight of the method you suggest.
John Johnson BEng
Under Construction
(Login stuart40a)
Forum Moderator
142.165.145.207
ok
January 31 2008, 6:02 AM
I only asked if you had seen it.
Current Topic - C1SP-7976-A
