No , steel part and it is matted to the toploader case and Toploader is 27" long . the hurst shifter is for a 64-65 galaxie And im thinking this tailshaft housing is for a galaxie or annother full sized car with a toploader, and from what others say on here and elsewhere it may have come from either a europe car or more than likely from central or south america. It has the 28 splines and looks good so I guess im just going to have to use it . My question , Mostly to Doug since you helped find the bushing numbers . snce this is a small block toploader with the HEH-G, but with a long tailhousing , am I going to need this bushing I got that you gave me a P/N for or am I going to have to just use a regular bushing ? I am getting rid of the truck bellhousing and have got a 64-65 galaxie bellhousing with the close bolt pattern so I don't have to drill it out and it is the shorter than the truck bellhousing. I dont know if I can use a 11 or 11.5 clutch on it though . THe PN on it is -4848339.
Again , its going behind a 428 , but is the small block trans.
Thanks again and sorry for the constant qestions , Im just glad there is a place to get help. Not many guys I know who ran these cars back in the day that actually worked on them first hand . |
