Click logo to enter advertiser sites
C6 Vibrations
December 3 2008 at 6:57 PM
  (Login wick246)
from IP address 72.11.72.223
Hello, I have had trouble with the C6 in my '79 Bronco creating a high frequency vibration as the vehicle accelerates. It also shifted too early and slips quite a bit. I have removed the transmission and disassembled it. I believe one cause of the vibration was a destroyed bearing between the converter and flex plate (there was only small ground up pieces of it left. The pump gears look good however the bushing in the center of the pump housing is chewed up. Is this bushing replaceable and is the one listed as " 36034
Bushing C6 pump body (babbitt)" the correct one? I'm following along with the badshoe video and have found a couple of other minor parts that need to be replaced and it needs a really good cleaning. Anything else I should be looking for?
Thanks,
Chad
