430 marauder
February 20 2005 at 4:13 PM
  (Login scott42580)
from IP address 205.188.116.132
I have an old ford motor it came out of an old boat.it has three dues carbs. the air cleaner says 400 hp marauder. numbers on block are 86y;1, 5751091 head numbers are 84k, 0063. I dont know what it is, can someone help please.
(Login KULTULZ)
MEL Forum Moderator
69.140.54.63
You Hit The Jackpot!
February 20 2005, 4:19 PM
1958 MERC SUPER MARAUDER.
Can you supply photos? What are you going to do with it? Where do you live (general geographic area)?
scott
(Login scott42580)
152.163.100.132
Re: You Hit The Jackpot!
February 20 2005, 5:55 PM
it had been setting 15 years so im going to take it to the mach. shop and see if they can bore it.I honed it and they all cleaned up good but one.the crank and pistons look good as well as the heads. im going to rebuild it and give it to my father as he is a big ford fan. I would appretiate any help i can get as far as getting rebuild parts and info Thanks.
Danny
(Login zeek62)
68.5.94.145
February 20 2005, 7:12 PM
you are stoked, that is a VERY desirable motor. Just so you know, this one uses a different size cam than the newer MELs, has a different valve seat angle than any other year MEL and the early '58 motors had some casting flaws. heres a post I left about rebuilds
http://www.network54.com/Forum/message?forumid=257364&messageid=1108330260
Current Topic - 430 marauder
Neue Seite 5
