Belated Answers
March 6 2007 at 6:34 AM
from IP address 69.140.42.35
Response to thank you.
"Did the 430 in stock t-bird have the same radiator overflow resevour as the 352 and will a 352 one bolt on?"
No. The J-BIRD had the elongated tank as does the later LINC. It is made that way to clear the fuel pump. As for an FE tank interchange, one would have to verify opening thermostat size on either tank and intake manifold.
Be aware that the 58/60 block has an FE bellhousing bolt pattern, the 61/65 430 has a modified pattern and the 462 retains this modified pattern and an additional pattern for a MEL specific CC.
The 63/65 4V 430 had unique piston crown design and reliefs in cyl heads for better burn. A 462 crank will go into a 430. It would require custom pistons (different pin height).
MEL (MERCURY-EDSEL-LINCOLN) Engine Specifications 1958/1968
383C.I. Bore 4.30” x Stroke 3.30” (1958/59) (MERC)
410C.I. Bore 4.20” x Stroke 3.70” (1958) (EDSEL)
430C.I. Bore 4.30” x Stroke 3.70” (1958/65) (LINC-MERC-TBIRD)
462C.I. Bore 4.38” x Stroke 3.83” (1966/68) (LINC)
  1. Thanks again - deano2469 on Mar 9, 12:38 AM
  2.
 Copyright © 1999-2009 Network54. All rights reserved.   Terms of Use   Privacy Statement
