<< Previous Topic | Next Topic >> Return to > DF
steering uneven
October 24 2008 at 11:19 PM
Recently replaced struts, and it is nice to not bounce going over speed bumps. However, now it feels odd with turns. It turns to the right easily, corners nice. Turning to the left requires more effort, though. I've checked the alignment and it looks good, (string method).
Before I start breaking it down, what might be the cause of this inequality? Of note, after shocks replaced, the steering wheel is turned a bit to the right.
Thanks,
Peter H
Peter R (Aus)
Re: steering uneven
October 25 2008, 2:13 AM
Hi Peter,
I had a similiar issue where the wheel turned easily one way and then wouldn't re centre. It turned out to be the little plastic bushing in the left side of the steering rack had disintigrated. I think Mad Matt sells a metal replacement now and it would never need replacing again. This could be one thing to look at.
Regards
Peter
Nice to not bounce going over speed bumps
October 25 2008, 7:52 AM
I have stock struts and I hate going over those speed bumps. It knock the fillings out of my teeth.
Are you telling me there are struts which are smoother over the bumps and still ride well the corners etc ?
HaXD
Herzel, in Israel
WhiteX
The late Green '85 X1/9
Not sure...
October 25 2008, 8:10 AM
What was the condition of the strut bearings? If they were broken or dry it may cause this, although frankly I'm not sure if it would feel one sided. I would check tire pressures first.
When I had mine apart to replace the top strut bushings, I cleaned and lubed my bearings (really a plastic bushing) with anti-seize. It felt like an improvement.
Mark Plaia designed and sold replacement bearing plates that used actual bearings. Perhaps he will chime in with more advice.
Gregory Smith
'87 Bertone X1/9 Corsa
'88 VW Vanagon
Olympia, Washington, USA
http://gregoryfsmith.com
Peter H
steering uneven
October 25 2008, 9:55 AM
Thanks for replies so far. The struts I used were from Summit, and rear strut tops from Matt. I know that the steering gear might be involved, since it shouldn't have grease all over one side of it! I bought a used one from Matt, and will try replacing it today. It is just that sometimes after you replace a part, thinking it was the cause of the problem, you find out it doesn't fix it! I like to avoid that.
Peter H
Current Topic - steering uneven
Xweb 'Calling All Cars' Bulletins:
Be sure to add yourself to Xweb's Registry and User Map
Xweb BUG REPORT/Q&A can help you get around!
Want Xweb's latest threads on your site? Click
Special section: X1/99 Concept forum
Xweb Forums Contacts:
Forums Moderators: Eric, Greg, Mark moderators AT x19web.org
Site Maintenance: Mac seattlex19 AT fastmail.fm
User Registry: Mark H markyharris AT gmail.com
User Map: Andrew rooy AT new.rr.com
XANA Homepage:
x19web.org
Login|Logoff
Xweb 101
Best of ...
