My next step is to remove the strips from the back and the front around the windows. I don't want to bend or ding it up. I just need it off to do body work and prep for paint....As always Thanks to all.......Bob
PS any tricks to remove the windshield without cracking it(to check for rust). Also any thoughts of a lexan rear window (cheap way to lose weight and get rid of the rear window defroster)?
I actually removed my x's windsheild today!
How detailed do you need? The short answer is an exacto knife, some piano wire (NOT guitar strings), 2pairs of vice grips and a delicate touch. It's not a big job, I think it only took me about a 1/2hour to complete by myself.
So far I've done a few windsheilds (no leaks so far...) and find the removal process very easy (I took out my X's completely alone and in about 20 minutes). Though this may have been easier since my car is completly gutted...
First I used a carpenter's knife (a good quality one with a non-sectioned blade) to cut the adhesive under the chrome trim. This was done by carefully running the knife pllel to the window (at some points, this involves sliding the body of the knife along the windsheild. If you're really nervous about scratches, you could tape up the knife...). As well, run the knife between the windsheild frame and the trim. You should now be able to start lifting up the trim, while cutting the adhesive stringers (the "melted cheese" looking bits). Minor bends in the trim should be easy to straighten later.
From inside the car, you need to remove the u-channeled rubber that lays between the window and the steel frame. This will be difficult since the window is glued to it. I did mine by starting at the top passenger side of the window frame and using crow's foot (a fork shaped screwdriver for removing interior panel clips) and a small dead blow hammer to push the rubber u-channel off of its track. once a few inches is off, I pretty much just started tuggin (did I mention I'm not a professional yet?) and the rest pulled right out. This was probably very easy for me since there is no interior or dash in the car and since the adhesive used was very flexible.
Once that it removed, I started cutting away adhesive from between the top of the windsheild and the frame along a 3 inch stretch. this is to cut a hole in the adhesive to push the cutting wire through. Once the wire was through, I attached a small set of vice grips on each side of the windsheild, with about 8- 12 inches of wire between them. When sawing, you need to angle the wire away from the edge of the windsheild. This is hard to describe but you'll fiqure it out. Work your way around the perimeter and your done sawing.
When I started to push my windsheild away from the top of the frame, the cut glue was sticking to itself, so I took the knife and cut the stringers (same as trim removal). Once out, I placed it on an awaiting (padded) panel stand to clean the rest of the adhesive from it.
I got the wire (about 16") from a junkyard for free. Sawing by yourself is easier than with a partner (though my 6'5" arm-span allowed this along the middle bottom), since you know your own rythym (sounds dirty...)
Hope this helps. If there's anything I left out or skimped on the details of, let me know
was looking through the best of's and found out that my adhesive was butyl. Urethane still cuts fine with a wire saw, though. I took out a 95 pathfinder windsheild at the wrecker last month that was glued with urethane and it took ten minutes longer.
That does sound like a good idea replacing the rear window with Lexan. I know Miwest X1/9 sells Lexan windshields but, I don't think he sells rear windows. I would like to hear if you ever find a way to do that.
I did this years ago. I've actually done 2 of them in different thicknesses. It's about as easy as taking the old out, and use it as a template on your sheet. I'm a little foggy, but one plastic is impact resistent, but scratches, the other is scratch resistent, but doesn't have the impact strength. I went for impact strength. The oe glass is 1/4" thick. My first window was at 3/16 and IIRC weight went from about 11 lbs to 3.5ish. Then for kicks I decided to try 1/8" and dropped another pound.
Be aware, care must be taken when cutting as not to crack the plastic. Also, with my thinner replacement you can feel it move in the weather stripping but hasn't leaked, and it's been 9 years. This winter I'm going to apply a light tint to it as the plastic is clear versus the tint of the oe glass.
Bobr... there useta be LOTS on this subject from Rocket Science approaches to...
October 24 2008, 5:10 PM
... Shadetree approaches.
All I know... is our local junk yard man uses Juan with a wire saw and an ice pick... and he starts a hole in the gasket and threads the saw in, then carefully cuts around the glass and lifts it out.
As far as reusing the gasket on the X... It's not needed or required.
Clean out the tray... (best to drape plastic over the entire dash and interior) and then make a bed of sealant to rest the windshield in... remembering to prop up the glass OFF the bottom with a couple of sticks to center the glass in the tray.
(trim sticks flush and just bury them there...)
Then cover the remaining gap and press the trim into place, letting the sealant hold it.
Wipe off the excess and tape the entire thing in place overnight.
OK... so this is the shadetree approach... let me also add that I used a GOOD grade of BATHTUB caulking also and it held and didn't leak for years. Black sealant looks a bit better, but the white could hardly be seen.
I'm sure there will be some Rocket Science approaches listed here also...
As for the backlight... Pull the engine cover and then unbolt the ledger that holds the window UP into place.
Using a putty knife... spread the gasket a bit between the glass and itself and spray in soap or WD40... inside and out... and work the glass by gently pulling DOWN. Be patient... it'll come.
Have fun!
My best,
Tony
Black Tooth and me... since 1983!
Disclaimer: This message does not necessarily reflect the views of the sender, or, for that matter, any other carbon-based life form; Any resemblance to actual persons, living or dead, is unintentional and coincidental; All models are 18 years of age or older; Dry clean only, do not use bleach, Tumble dry and remove immediately; Do not bend, fold, staple or mutilate; Anchovies, cheese or jalapenos may be added to orders upon request for an additional charge; Professional driver on a closed course, do not attempt to duplicate; Your actual mileage may vary; No substitutions are allowed; Available for a limited time only while supplies last; Offers are void where prohibited by law; Humor is provided "as is" without any warranties expressed or implied; The user assumes full liabilities and originator is not liable for damages due to use or misuse; We are an equal opportunity employer, with no regard to race, religion, sex, or sexual preference; No shoes, no shirt, no service; Read at your own risk; This post may contain material some may find to be objectionable; Parental advisory: Explicit lyrics; keep away from pets and small children; limit one-per-family please; No money down; No purchase necessary; Ask us about our guns-for-dope trade-in plan; You need not be present to win; Some assembly required; Batteries not included; Action figures sold separately; Contents were packed full at the factory, but may have settled during shipping; Peanuts and peanut products are produced in this establishment and also consumed by the author; Sanitized and sealed for your protection; Do not use if safety seal is broken; Do not use while operating a motor vehicle or heavy equipment; Safety goggles may be required during use; Use gloves when handling; Call before you dig; Use only with proper ventilation; For external use only, if a swelling, redness, rash, or irritation develops, discontinue use; Do not place near a flammable or magnetic source; Keep away from open flames; Avoid inhaling fumes or contact with mucous membranes; Contents under pressure, may explode if incinerated; Smoking may be hazardous to your health; No smoking allowed, except in designated areas; The best safeguard, second only to abstinence, is the use of a good laugh; Text is made from 100% recycled electrons and magnetic particles; No animals were harmed while writing this post; No salt, MSG, preservatives, artificial color or flavor added; If ingested, do not induce vomiting, If symptoms persist, consult a comedian; Ribbed for your pleasure, slippery when wet; Must be 18 to enter; No one under 21 allowed; We check IDs to age 40; Seniors Welcome; Ask for our Senior Menu; Present discount coupons to cashier before totaling; An 18% gratuity will be added to the total for parties of 8 or more; We reserve the right to refuse service to anyone. Return all carts to the store; No dogs allowed, except for the visually impaired; Penalties for early withdrawal, one size fits all; Offer is valid only at participating sites; Prices slightly higher west of the Rockies; Allow four to six weeks for delivery; If defects are found, do not attempt a repair, return to an authorized service center; Please remain seated until the vehicle has come to a complete stop; Objects in the mirror may be closer than they appear; Fasten seat belts; In the unlikely event of a loss of cabin pressure, oxygen masks will fall from above, cover your face first, then assist those around you. Your seat cushion may be used as a floatation device. This disclaimer is invalid in the event of hurricanes, floods, earthquakes, sonic booms, vibration, electromagnetic radiation from nuclear blasts or any other act of war, unauthorized repair, improper installation, misuse, typos, misspelled words, missing or altered signatures, and incidents owing to computer or disk failure, accidental file deletions, and Acts of God. Other restrictions may, or may not apply.
I've run a lexan rear window for years(lexan is polycrbonate,and tough but soft)
October 24 2008, 11:07 PM
it is available with a hard coating that helps some. Plexiglas is acrylic,it's harder,more scratch resistant,but brittle and breaks into spearhead shaped shards,not good.
I went to the extreme of 5/16" lexan,hard coated,then cut 2" holes in the bottom(covered by the body )AND drilled the retainer strap to save a couple more ounces.
Xweb 'Calling All Cars' Bulletins: Be sure to add yourself to Xweb's Registry and User Map Xweb BUG REPORT/Q&A can help you get around! Want Xweb's latest threads on your site? Click Special section: X1/99 Concept forum
Xweb Forums Contacts: Forums Moderators: Eric, Greg, Mark moderators AT x19web.org Site Maintenance: Mac seattlex19 AT fastmail.fm User Registry: Mark H markyharris AT gmail.com User Map: Andrew rooy AT new.rr.com
